Fp Green Vs 3076 Kit
i'm sorry but considering the options out for evos, 3076's suck. The green will make just about the same amount of power and spool up way quicker. And its cheaper. The red will outperform the 3076 by FAR.
Only 30r worth going with is the 3082r
A Red outperforming a 3076 by Far is a exaggerated statement. That statement pretty much says that a 35r isn't worth buying when you can buy a red.
Stay with the Green. If you want 3076+ power, go with the RED. The tuner will ALWAYS be the biggest difference in what one car can make vs another. Potential is a small part of the equation. If the tuner doesn't get the power out of a 3076, but another tuner maximizes the Green on Pump, the Green wins. Quicker spoolup will beat higher peak numbers MANY times. STAY WITH THE GREEN LUKE! If you want to kill a well tuned 3076, do it with a RED. The choice is simple.
It also depends on price to...I def would not go with a 30r if I was buying a new kit and paying $3k plus for it...go 35r right from the gate..
reg 35r with a .63 hotside or HTA with an .82..
i def should of went bigger
lag is overated big time..
I mean a reg 35r with an .82 is def laggy but and hta or a .63 is perfect for a daily driven drag car.
now if you want to autocross it go green i guess..
lol
When i explain to people the difference's in my car going from a 20g-9 to a 30r I pretty much say that there is finally life past 6krpms, especially with my 35r, there is nothing like watching (and feeling) that little boost needle hold 2.5 bar until i shift at 8krpms
Yah the green didn't net me as much power as I'd hoped, but it did gain 10-20whp above 5K on 91 with a HFC.
But then again 317/293 on our local mustang dyno was very strong for a stock turbo car on that dyno, so it's really hard to say if my green was underperforming or if my stock turbo was outperforming the average stock turbo car.
For reference I think my car did 230 something bone stock on this dyno.
I would guess that the green would be an autox beast (depending on the track), but as others said on this thread, you just have to feel how a 3076 pulls to 8k (or a 35r for that matter) to really appreciate how much fun it is.
Hey guys, I have a 2005 Evo 8 with the mods listed below in my sig. I have a buddy who has a 3076 turbo kit and is looking to sell it. I was planning on getting a Fp green but he just asked me if I was interested in the kit. ....
Mods:Megan Racing Turbo back exhaust, Megan Downpipe, Megan cat delete pipe, APS BOV, Greddy profec B spec 2, Crossed drilled & slotted rotors, Apexi Air Filter, Dynoflash from AL.
1. your 'buddy' is ditching the 3076 in favor of an FPRed ... IMO that's not an opportunity, that's a hint (gee, I wonder why he's going to an FPRed) ... stick with the green
2. At your mod level, you are not going to be able to take full advantage of the performance that either a 3076 or an FPRed can offer ... stick with the green, unless you've got big plans for better supporting mods.
3. If you're planning on running pump gas, you're going to really have to up the supporting mods to be able to get significantly better numbers out of a 3076 or FPRed over an FPGreen ... stick with the green,
So, looks like Green 3, 3076 0 ... this is a no-brainer, IMO.
l8r)
for the record i've put down 392@wheels(on a cartec dyno-low reader) on pump gas on an externally wastegated green,i hold 2.0bar up to the redline which is 7800 on my setup and that's because i believe that is pointless to run the green over 2bar on pump.
