valvoline 75w-90 gear oil?
Yep, that's what you are supposed to use. I recommend Redline MT90, everyone uses it because it keeps your gearbox less slushy after the oil warms up, has a great viscosity. I'm using Mobil 1 75w-90 right now and I'm regretting it, going to switch real soon.
hey man, there's probably EXTENSIVE discussions about this in the forums...but don't use any lubricant that says GL-5 on it. They are too slippery for our synchros. I've been through this mess with my DSM already back in the days. your gearbox will be 'crunchy' and shift like crap.
the off-the-shelf lubricants like mobil and valvoline i've seen are ALL GL-5.
here's a segment of Redline's sight for using their oil/disregard other stuff:
http://www.redlineoil.com/buyonline.asp?id=2
Lancer Evolution:
Works with Lancer EVO VIII, EVO MR, EVO X, and EVO RS and includes 6 quarts of 10W30 engine oil, 2 quarts of MTL and 1 quarts of MT-90 (add the 1 MTL quart, then the remainder with MTL-90 to meet the Evo's 75W85 gear oil spec), 1 quart of 75W90 for the center differential and 1 quart for the rear differential, 1 bottle of WaterWetter for the radiator, 1 bottle of SI-1 Complete Fuel System Cleaner, a sticker kit, and a Red Line Oil embroidered hat.
have fun.
edit: oh yeah..you need GL-4 ONLY lubricant for the transmission. heh.
Lancer Evolution:
have fun.
castrol also makes 75w 85 gl 4 specifically for mitsubishi vehicles
http://www.castrol.com/liveassets/bp...ans_B13127.pdf
i dont know if it is available in the USA
Lancer Evolution:
Lancer Evolution:
if the car is just being used as a daily driver not tracked or driven hard can you use the valvoline duragear 75w-85 its also a gl-4 rated oil?? or will it be notchy, reason i ask is because in nz it is only $12 NZD a litre.
most of the threads about the redline cocktails, say best for 5 speed, how does it perform in the 6 spd boxes?
(add the 1 MTL quart, then the remainder with MT-90 to meet the Evo's 75W85 gear oil spec)
i take it thats for a 6 spd box, i would like to try the amsoil MTG but i cant seem to find it down here in NZ, and need to the car on the road today. can get SVG but it $48/l for us.
when hot, its ok
FS[SouthEast]: Mivec Cam Gear
hutch959
10
Nov 25, 2016 05:35 PM
superdupersti
23
Feb 5, 2008 06:40 PM
freedom
May 5, 2004 04:44 AM
