Cutting honeycomb out of stock MAF???
Old Aug 25, 2008, 07:00 PM
  #31
Mellon Racing's Avatar
I don't recall the brand epoxy it's been too long but I got it at Advance Auto and no pics
Old Aug 25, 2008, 07:10 PM
  #32
9sec9's Avatar
Originally Posted by RyuEvoIX
Hence the original silicone that's in place from the factory. I remember that "mod" back in my 3g Eclipse days.
I wasn't around during those days. I actually figured this one out on my own. I must have been sleeping during that decade, or two. The MAF lip was just too high to let it go without smoothing the airflow.
Old Aug 25, 2008, 09:12 PM
  #33
DynoFlash's Avatar
Originally Posted by Ted B
AThe 'honeycomb' is there to create laminar flow through the meter. Without it, there is increased turbulence, which compromises the consistency of the signal, and it throws off the entire calibration curve.
On my Subaru which went 11.1 on the stock ecu and motor (hard to do with a STI) I used a custom Big MAF from Cobb tuning which had a honeycomb in it, it was a large 80 mm tube and the honeycomb was epoxyed in and rivited very securely. It was amazing to see how well that unit performed when compared to other non honeycomb big maf units I have tested in the Subaru scene.
Al
Old Aug 25, 2008, 10:36 PM
  #34
EMC
EMC's Avatar
I accidentally damaged mine when I first put in my intake so I ended up taking it out. The only thing I noticed was if I suddenly engaged the clutch while normal driving the idle would occasionally drop almost to 0 then come back up to normal. It didn't do it every time, just once in a while. After a few more mods I got tuned and it seemed to go away. I'll probably end up replacing it though.
Old Aug 26, 2008, 05:15 AM
  #35
RyuEvoIX's Avatar
I know this whole discussion is about using the stock MAS but wouldn't it be more beneficial, airflow wise, to convert over to the GM 3inch MAF?
localtoys73
Oct 6, 2010 12:22 PM
Kilratio
12
Jun 9, 2010 07:49 PM
jamie_v1
48
Jan 7, 2009 10:12 AM
NIevo
Sep 10, 2007 10:06 PM
Boostin4g63
Jun 21, 2007 09:39 PM
Quick Reply: Cutting honeycomb out of stock MAF???
