FP Red, E85, 454hp/408tq @ 26psi
Old Sep 23, 2008 | 11:03 AM
  #91
mpfcc's Avatar
yeah economy cruising I'm sure, not WOT lol
Originally Posted by Wicked E
I did 18.5-19.0AFR on the drive home...
-E
Old Sep 23, 2008 | 11:19 AM
  #92
Wicked E's Avatar
Originally Posted by SuPeRNeT
not WOT.. your car would have bucked around like a bull
Boy do you know this!!
-E
Old Sep 23, 2008 | 11:20 AM
  #93
Wicked E's Avatar
That was NOT intentional at all. I've done somewhat my own road tuning to bring that back down to 14.7-15.0 range.
Now, I dare all you guys to try and NOT boost for 2 months...
-E
Old Sep 23, 2008 | 11:32 AM
  #94
mpfcc's Avatar
2 months aint nothing, try 2 years. I had a 1994 RX7 that I dropped $15k, went To4R, setup for about 500 to the wheels...had a tuner come out from Texas 3 times in a 2 year period because the car would go lean above 5000 rpms. So I went 2 years with absolutely no boost because I would have popped my motor. Sold the car, turns out the throttle position sensor was installed upside down so the secondaries (1600's) weren't coming online! Oh well, maybe it was meant to be...he fixed the problem and during tuning blew the apex seals out the exhaust
-E
Old Sep 23, 2008 | 12:49 PM
  #95
2.4ls20g's Avatar
I miss that car.
Old Sep 23, 2008 | 01:35 PM
  #96
zedevo's Avatar
@ mpfcc : did the FPGreen can get same or more HP on same mod's ???
Old Sep 23, 2008 | 04:10 PM
  #97
mpfcc's Avatar
I don't quite understand your question.
Old Sep 23, 2008 | 04:17 PM
  #98
tnt1106's Avatar
no. that is why the green is smaller than the red. Red being bigger turbo, will make more HP
Old Sep 23, 2008 | 04:19 PM
  #99
mpfcc's Avatar
**update**
Huge boost leak was found at the LICP. The t-bolt clamp was cockeyed and the coupler was slipped off the pipe. As soon as the boost leak check started all you could hear was air rushing out of it. After that was fixed, another check was ran and one of the t's for the vacuum lines was leaking as well. Problem is now solved, no boost more boost leak. I think this would explain the reason I boost tapered so bad and why the turbo had such a lazy boost curve.
Tuner is a stand up guy, I called him with my find and he's paying the shop who did the boost leak check and fixed the problem. Also going to retune my car and get those AFR's under check I hope at around 11.7 - 12.2 ish I will post results once the car is done...AGAIN lol
Old Sep 23, 2008 | 09:12 PM
  #100
MuslimEvoFreak's Avatar
^^ And I thought those t-bolt clamps were god amoung others. I am glad you found the problem, now lets see some more numbers!
Old Sep 23, 2008 | 09:50 PM
  #101
Wicked E's Avatar
Good stuff. Now you understand my PM about why I support Carz. Stand up people stand behind you.
-E
Old Sep 23, 2008 | 10:02 PM
  #102
projectevo9's Avatar
That's not much higher than the FP green!
Old Sep 23, 2008 | 10:08 PM
  #103
Wicked E's Avatar
Can you read?
-E
Old Sep 23, 2008 | 10:10 PM
  #104
Turbo Kyle's Avatar
Cant wait for new results
Old Sep 23, 2008 | 10:13 PM
  #105
94AWDcoupe's Avatar
A good tuner checks for boost leaks before the tune.
Quick Reply: FP Red, E85, 454hp/408tq @ 26psi
