hallman pro rx in cabin
Well i already had the hallman pro rx but I just recently purchased the add-on kit to mount it in-cabin... i followed the instructions to the T but for some reason the boost knob just doesn't make a difference.... its stuck at 12psi damnit
anyone else have any experience with this?
Thanks
Thanks
I have the same MBC w/ in cabin adjustment (which is awesome); make sure the cable isn't binding and is turning freely. Then verify you have the MBC running to the correct locations for boost/vacuum source. Shouldn't be too complicated as you are basically replacing the knob on the MBC w/ a cable that runs into the car.
EVO_803
Aug 18, 2007 09:48 AM
use2vtec
Mar 9, 2005 09:59 AM
