best way to break in a clutch?
Are you putting in the clutch yourself? If you are, can you let me know how it goes? I have my Quarter Master twin waiting to be installed. I was told you need (4) M6x60mm 1 pitch bolts for the TOB. Don't know what else to expect. Especially with all the shims that come with the clutch.
i actually have 2 friends who are doing it
one of them who posted in here ( psphinx81 )
but yes i will def let you know how it goes
i will be taking a ton of pics and will probably post it on here when we are done
You should find out from a person who has knowledge of the exact item you are installing (manufacturer) so if you blow your **** up you might get help. If you just go buy what other people say (usually just an opinion) not fact, you could be installing another clutch. Good luck!
![Beer](https://www.evolutionm.net/forums/images/smilies/beer05.gif)
1 Post
I do know that the Exedy twin disc clutches are not heat treated from the factory. This is why the break-in period is so important.
Breaking it in heat treats the clutch so that it can cure correctly. You can reduce the life of the clutch by not doing a proper break-in.
After spending the $$ and time - might as well do it right.
-Bink
-Bink
ctevo
Sep 11, 2004 01:51 PM
300zx, boost, break, breaking, clutch, evo, exedy, expect, installing, lancer, mitsubishi, proper, quartermaster, quickest, safest
