turbo-install tips
turbo-install tips
Hey guys any threads or how-to's floating around.... couldn't find what i was looking for via search
im bolting up fpred, epm o2, ad ported exhaust manifold
and tips from experience? or what was difficult...
I have done one on a 99 dsm but its been awhile...
Thanks guys
Thanks guys
i know draining the coolant and taking the radiator out frees up alot of room...
seems like we drained the oil on the last install to avoid heavy leaking from the oil lines from the turbo to the motor... is this required?
It is not required, but it will be a lot more messy if you don'r drain the oil. Just drain it. That way you will have fresh oil for your new turbo as well. Definitely remove the radio. The loving that it will get from the wrench/socket will not be pretty. Biggest thing is to take your time if it has been awhile and make sure you pay attention to where the bolts go...or put the bolt back in the hole you got it from.
if your replacing the mani, turbo, and o2 then just un bolt your down pipe, unbolt the mani. then take all your oil and water lines off, disconnect your o2 sensor, and pull the whole assembly out together. i would suggest going to autozone, advanced, etc. and get a new from o2 sensor. the past 2 o2 swaps ive done the 02 sensor got damaged because of how much abuse they take from trying to get those dang things out. you can get the generic once that cost like 55 bucks and just wire it in. then have all your new stuff already assembled, just bolt it to the car. hook up your d/p water and oil lines, intake, and plug in o2 sensor etc and then your good to go.
What about priming the turbo or getting oil in the turbo before actually firing up the engine. I read on an old post about disabling your ignition system? Is this true or could I be wrong? Please more info on this for I will be doing the same project. Just waiting on inj, epm dump, and port & coated mani for the RED.
spray the 02 housing with some PB blaster, and also all the other bolts! I have removed my upstream 02 sensor like 2 times and havent had a problem as long as it got some pb blaster time to soak in. All cars are different, and so are their mechanics!
i agree that you normally u dont have to replace them i was just saying that he might have to get a new one and to be careful. i dont think i worded it the way i ment to. and yea you would want to wait till the assembly is out of the car before you try to get at the o2 sensor. but if you car has over 50-60K miles unless your just tight on money right now you might was well change it so you have a fresh o2 because your car uses that o2 for cruising afr so a fresh one wouldnt hurt. but thats just my .02....
I am gonna be the second one to tell you that you are wrong. Once the entire turbo assembly is out of the car then just let everything soak in pb blaster so it comes out easily. Take your time or thinks will break. Also I would never install a cheap 02 sensor on my car anyways.
stigmeister
Feb 27, 2017 12:10 PM
WTB[Northeast]: Buschur Racing Exhaust Tip
pinoyevo23
Jun 16, 2016 12:16 PM
WTB[Northeast]: Buschur Exhaust Tip
pinoyevo23
Sep 20, 2015 09:23 PM
