Why did my turbo blow up?
ok heres the thing
i had a evo 8 turbo and it blew up so i upgraded to a supposably 11k miels used evo 9
when it got installed it was amazing just not long ago it started whisling and gridign and all its almost gone barely can drive
heres the tihng this turbo i didnt even have for 20k miles and its gone
-i didnt even race it actually most of it was just crusing because i took of my exhaust so i dind't punch it all the way
what would be the reasons guys
also i got a new motor built not long ago would that influance that in any way?
i dont think turbo was fault
and i didn't abuse this turbo
could there be any issues with oil delivery? how do i check? please help
i don't want to loose another turbo
1 Post
Josh
Turbos use a thin film of oil to suspend the shaft between the bearring. If you have metal in your filter from a motor build that didn't have the correct tollerences...than that could be the reason you are going through turbos in a relative short timespan.
i never even thought about that i will make sure ill check my filter and ill send you pictures
i know there is a lot of reasons for my turbo to go out but what would be the most prabable one
i know it was a good turbo and i know i didnt abuse it i want to narrow it down to some defect in my car
Matt, dont feel bad. Most people, even "shops" don't catch potential problems until it is too late. Imagine how you would have felt if that had been a brand new turbo? You would have likely considered it to be defective for lack of a better idea.
Check this out. This is a BRAND FREAKING NEW Mitsubishi Motor Company oil feed line, straight out of a sealed plastic bag.
If this line had been installed instead of being very carefully inspected, it would have spit its flaky corrosion directly into the turbo bearings, and if that were not bad enough, the corrosion even partially blocks the already oil restrictor orifice built into the factory oil feed line.
I was about to make a new thread on this very topic when I saw you thread about a failure.
No reason for it to be in black and white, does it look like that? The newest lines are coming in as silver instead of gold, same thing for the color of the plating on WG actuators. It is a color pic, just not much color in a silver oil feed line This was a problem for a guy on the norcal board a few weeks ago, he had a chunk of this stuff in his thrust bearing.
