Which ACT flywheel would be best for me? Streetlite or Prolite??
#31
See edit. A dowel would not prevent the bolts from loosening.
#32
What I saw ACTman say before was
These engines, especially when heavily modified have tremendous torsional vibration. In most cases the flywheel bolts do not come loose and cause the flywheel to come off. Usually the flywheel shifts back and forth under the fully tightened bolts because of the torsional vibrations, and this causes the bolts to work loose. Locktite and safety wire will not help to prevent this. Only using a higher torque value (stronger bolts if needed) or additional dowels in the flywheel/crank will prevent the flywheel from shifting and working itself loose. According to my source 98ftlbs is the torque specification for the stock bolts. I would use at least 115ftlbs with the engine you are putting together. Consult an engine builder for their recommendation.
#33
It'll need to be a tight (press for) dowel for it to work. And most dowels are a slip fit, they have tolerance. I haven't any issues with loosening flywheel bolts on bshaft deleted motors I've put together without flywheel dowels.
#35
Yea. Red loctite and 100ftlbs. One I did is even a fidanza aluminum flywheel in a GSX. Has had an issue for 5k miles.
TheMyth
Jan 25, 2018 06:23 PM
FS[Northeast]: 2005 EVO 8 RS Interior Pieces
Giuna99
13
Jun 26, 2016 08:45 PM
