haveing major troubles installing clutch
well, just getting the tranny out was a big *****, now it looks like the spec clutch plate i have may be too big. when i torque it down to the fly wheel the pressure plate center part seems to stick out farther than it should... and it also feels like it is tightening too quickly when torqueing it down. for those of you that installed their clutch, how much tighter was the clutch put together than stock. also, the factory clutch plate is about 1.5 millimeters thinner than the spec clutch plate... but wouldnt this be true because the stocker was dead? i mean it would spin under relativly no throttle. im affriad once i get it back together the clutch will not disengage. please answer asap, as we are working on it right now.
if the new clutch is an aftermarket or upgraded clutch you will see differences in the install. I am not rich like most people seem to be so Ive had to replace about 4 clutches for my personal car and friends. my wife cant drive a stick w/out screwing it up. if the pressure plate wont make flush contact with the flywheel you do have a problem. make sure the alignment tool is in right
What can contribute to a "rattling" noise, as the dealer described it?
I had them put in an Exedy Twin Plate, and this the the noise the described when the clutch is pressed in.
Ken
Ken
Ken
Ken
Only other cause for noise with clutch depressed I can think of would be related to a throw-out bearing issue,.or possibly a clutch disc coming apart which is highly unlikely in your case.
My .02
N10S
Thoe99
378
Jul 30, 2018 05:56 PM
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
Johnr352
13
Feb 4, 2014 04:35 AM
