Mechanic put castrol gtx oil in my car >=[
#31
True you can mix them but it doesn't mean you should. You dilute the benefits of the synthetic. On a turbo car that requires added heat resistance like the EVO, using conventional or a mix is just shortening the life of the motor and or turbo. Will it kill your motor right away? No, Will it later? Theres a good chance.
#32
Its really not THAT big of a deal honestly. All you had to do was change it as soon as u could. People really have no clue huh? Like your motor is going to fall apart or something. Just change it back.
I ran a non synthetic blend when breaking in a built motor, then switched to synthetic, then went back to the non synthetic blend I was using before. I had burnt 1 qt of the synthetic on a 600 mile trip but i was also driving very aggressively. The motor in question is still running over a year later, at 550+whp pump/meth EVERY day for over 10k and it runs healthy!!!
Its not a big deal
Its not a big deal
#34
People, the sun will still rise tomorrow. Chill.
And if you want to be really ****, mobil 1 isn't even really a true synthetic anymore, but don't worry, your motor will still run on it. Trust me, I know things...
#36
cliff notes: orange fram filters use a cardboard backing plate inside the filter for what its worth.
#37
listen. i live at the carribean y have an evo 8, with stock evo 8 turbo, non ported exhaut ot intake, i only have cams, intake,upper pipes, xs power intercooler(cheap), ebay down pipe and 02, cutout. and i run my car daily!!! i am very very near 400awhp @ 24psi i wont say exact numbers but is very near!! and i run my car with castrol 10w 40!! and i use my car for work, drag and even road racing!! so whats the big deal!! i change the oil and fram filter every 2000mi and there is no sign of wear at the bearing!! just checked!! So dont be that mistic with it!!
#40
Im not going to even touch the syn. oil vs conv. sublect, its not worth my time. BUT I will add that Mitsu and Toyota both use OEM Denso filters. There casing, backing plate, and filter media is definitley superior quality. If you are to cut one of these open a nd compare a fram and napa gold to one of these, you can see the benefits over the lesser.
#41
jesus what do we drive ferraris?, why do people freak out when 89 octane or reg oil is put in... it can either be changed or burned off with out going into boost, its a mitsu not something rare like a lamborghini or ferrari......
#42
Its not a big deal
Its not a big deal
#43
Also ONLY the gold is a "good" filter the silver and pro select are a inferior filter.
#44
GTX is a fine oil as is nearly anything you can buy (including the supertech at walmart). Mobil 1 synthetic really has no place in a car like the evo being that it runs on the thin side of the weight scale and doesn't have enough zinc.
Its really funny how **** some people are about motor oil but many of these people neglect other more important lubricants in their car such as the drivetrain fluids.
#45
As others have said, it's NOT a big deal. As Steve already said, dyno oil is often used to break in built engines. When I did an SR20DET swap, I used 20w50 dyno oil for the first 500 miles then switched to synthetic. Then I had an oil leak once, needed to re fill on oil and all I could get was dyno oil, so I ran that for 3,000 miles of hard driving (drifting), then switched back. That engine performed like a champ for me, and Martin @ XAT Racing in Tampa, and the guy he sold it to... etc. Read up and you will see that unless you run an inappropriate weight for the temps you will see, it really doesn't matter that much.
