Please look at pics. 35r bent turbine fin (barely)
Hey, I was taking my exhaust housing off of my turbo in order to switch out to a .82 a/r and noticed this fin barely bent. As always I was EXTREMELY careful while taking the hotside off so I don't think this happend because of that.
But my question to ya'll is do you think this fin is bent enough to worry about fixing this. I'm kinda a perfectionist when it comes to power mods so I'm leaning towards sending it in to somewhere to get it fixed but I was just wanting to get ya'lls opinions also.
also, I did barely touch the area with my fingers after I realized it was bent, so I'm thinking thats why it's a different color than the others.
the very small red circles is where the damage is.
thanks,
John
thanks,
John
YES! I would have it fixed/replaced. As was said earlier, at the rpm's that turbine wheel sees, any small imperfection will eventually tear it to pieces. (ie: damaging bearings)
Hit up Blouch turbo as an option too! Super easy to deal with, fast turn around time, and reasonable $$
yeah I was just wondering where I should send it....garrett,precision, forced perfomrance,blouch???
also anyone have any idea what this might cost to get the turbine wheel replaced? I would just call somewhere but everywhere is closed today. I'll definetly call monday though
John, I am 100% sure that small bend is not a problem. It wont cause imbalance, there is no material missing. There will be no performance difference between that one and a new one. Besides the only way to repair a bad turbine wheel is with a new 950$ center cartridge.
My advice comes from years of experience using damaged turbos. Not from just looking at it and getting a bad feeling about it.
not sure why I respond to your questions. you never listen to my advice.
you dont even want to see pics of the damages turbos I have run. you are making a big issue over nothing. if some vender says that turbo needs work its because they are not honest and want to pray on your ignorance and desire to have perfection.
and I do listen to every bit of advice that I can get
I'm a Garrett Dealer and his price and parts statement are correct. I also rebuild here in house and back the above statement.
Run it or replace the CHRA, only two options available. If it were mine I'd run it.
