How Can I Get More Power Without a Turbo Upgrade???
I Need Engine & Power Upgrading Advice for Road Racing
I have a 2003 Evo 8 that I use 50% for track - and 50% for street use.
I run road racing circuits such as Pocono, Watkins Glen and VIR.
I want to build up the car for more power and durability, WITHOUT going to a larger Turbo and using the stock turbo. Obviously, cost is a factor.
Can this be done?
My current mods are:
Injen Intake
Turbo Back Exhaust, (Invidia Downpipe, Perrin 3” Evo cat, and Borla exhaust)
Walbro Fuel Pump (stock injectors)
HKS 272 cams
Tune, @ 22-23psi boost
All else on the motor is stock
The car has been dyno’d at 310whp.
What else can I do that is “cost-effective” to get more power?
How much power would I get?
Can this be done?
Injen Intake
HKS 272 cams
When you are talking about the FMIC, there really arent to many cheap choices out there. Dave Buschur did an intercooler test a while back, and the BR Race Front mount was the best, AMS Race Version was also good, and The Garret intercooler was also good.
check out s-max intercoolers. very nice guys there, and they have kits that run co2 right through the intercooler making the air temp. drop a lot. its basically like one of the front mount sprayers, but built in. they work great and also come in a variety of sizes.
check out there website:
http://www.speedmaxperformance.com/
Put the stock air box back on the car. Road racing with an open filter is not good for power.
Get rid of the cat. You can sell it for scrap on ebay for nearly $200.
Put race gas in the thing and crank up the boost.
29psi daily.
I'll tell you guys a secret, the MHI compressor maps for the EVO8 and EVO9 turbos show the EVO8 having a flow advantage. Very slight, but there. I know I will get flamed for that, but just pointing out what I know to be true. I think there is plenty of evidence to support this actually, some of the quickest and fastest stock turbo records are on EVO8 turbos with 10.5 housings.
Replace the stock FMIC prior to considering turbo upgrade also, good gains from the Garrett IC cores.
Perrin, nesei...I have buschur deluxe and like it, but there are bigger cores out there. If I did it again I'd go buschur RACE core and make it fit with stock bumper support.
