HELP!!! OIL Leak
Your right / inner tripot (CV) boot is leaking grease. Most likely it's seeping through the clamp, but check to see if the boot is split. If not damaged, then just replace the clamp. Doesn't look like a lot of grease has come out, but you might want to squeeze some new grease into the boot before you re-clamp it. I like the style of clamps that you have to pinch to close with the special pliers.
This is not oil my friend, CV boot gone, go to mitsu and get new CV bot it does come with the greese, but i would inspect it first maybe clamp broke... if clamp get CV greese from mitsu dealer if you see a CUT on CV bot , replace it asap. IT only leaks when you drive it because it split open.
good luck.
good luck.
Sideck
Sep 9, 2009 12:10 AM
wd_cross
27
Oct 11, 2008 02:54 PM
egk-69
25
Nov 12, 2006 07:25 PM
