which wideband?
#36
Old Zt-2 Widebands (2004 models) did not log boost beyond 25 PSI. Newer ones log up to 60 PSI. FYI we offer an upgrade for the old ones.
#40
You sir are completely uninformed and ignorant. The NGK Wideband uses pretty much the best sensor on the market. Mine has been dead accurate for 50k and now that its pinned directly to my ECU logging in EVOSCAN and Mitsulogger are no issue.
Read up before you post useless crap. Friggin EVOM ceases to amaze me
#42
i have an innovate and i like it but i really want to switch to the zietronix stuff with the lcd screen. I have heard people having some trouble logging it correctly in evoscan thought. Also would i be able to log boost from the zeitronix one in evoscan as well as my afrs???
#44
On a side note, I've been kinda thinking about making a controller that reads WB and map data to work with evoscan. Compact with a small LCD to display boost, a/f, maybe even timing and other fun stuff. If people would be interested I might be able to make some time to do that.
#45
The point is not whether or not you have EVOSCAN DUH.
The point is your making a bold statement with nothing backing it. Like I said the NGK kit uses one of the best proven wideband sensors money can buy.
By you just using a blanket statement saying its junk is just showing how your pure ignorance shines.
Go troll somewhere else
