HKS 264's
search you will find answers.
but let me tell you now, don't waste money on hks 264, HKS 272s are perfect for daily drive, won't loose lowend.
why are you trying to compare comp 280 to hks 264? these 2 are totally different animal.
People are ditching their hks 264 b/c they are weak
Not weak at all. Make alot of mid and top end power. Nice idle too.
I agree with the 272's... I used them with my full bolt on car and stock turbo and the car made 383, I added the AMS VSR and the AMS 50 trim and the 272's made 505 whp and 475 torque!
I would either go with a different setup or go with the 272's. I had a custom flashed ecu and they idled fine.
These are all subjective results though. For the most part I think HKS 264's and 272's are about equal. But by virtue of design the 264's shift the powerband down lower in the RPM compared to 272's. More duration allows the intake valve to be open longer (to the point where the piston is moving back up the cylinder) and pull more air into the cyclinder IF the RPM's are high enough to create kinetic energy for the air charge. At lower RPM's the long duration hurts you because the piston pushes air OUT of the cyclinder.
For a stock turbo car looking to maximize spoolup 264's are the goods.
Here's a plot from the OG AMS DSM cam test, the 264's make more torque then 272's, spool better and don't give up that much on the top end.
http://www.amsperformance.com/camtest.php
EVOTEXAS
92
Jul 21, 2010 09:24 AM
fromWRXtoEVO
Mar 17, 2007 06:05 PM
