Did a boost leak check... heres what I found
A ruptured vaccum line going into boost control soleniod, bad leak at turbo inlet coupler, and BOV leak... Fixed all leaks besides BOV and car pulls much harder, and my idle isn't messed up anymore... So moral of the story do a boost leak check every now and then...
why do you think my car wants to die like i'm leaking vacumn or something .. happens when i've been driving for a while and come to stop press the clutch and the idle drops lower than normal and vacumn shows -14 instead of -16
I got a 3" PVC threaded coupler and a threaded plug, epoxied the plug in and drilled a hole into the end of the plug and inserted a valve stem into the hole. I recommend using a bolt/screw in type valve stem... then took off the MAF and installed it in my intake tube as it is easier to get to than my turbo inlet... Make sure to cap of MBC, and Crankcase as mentioned previously...
