A few pic's from my buster rear end
#33
It was Trents fault anyway, I haven't broke anything..... yet, knock on wood
#37
Al according to the parts guy the diff it's self is different inside. 9sec9 told me this on Monday aswell. From what I was told the rear axles are different where they go into diff... I hear they are bigger?
#38
It was sad to see your car break yesterday Jeff but you took it like a man and just fixed it. I was proud of you.
BTW, if you guys don't let me eat for 36 hours..........someone will probably die 'cause I am going to be one hateful ***** f....
#39
http://fartfactory.com/widget/widget...q2=4&q3=2&i=60
#41
someone mentioned cryo treating earlier.my understanding is that cryo treating works on problems with wear(ie brake rotors,bearing surfaces etc.) .if you were to cryo treat the gears for wear but wouldnt help the pinion for strength.actually i think it would make the parts more brittle with the shock loads.please correct me if i am wrong on this.
#42
vwjeff
52
Apr 25, 2013 08:09 AM
vwjeff
Nov 5, 2008 06:57 AM
vwjeff
53
Jan 14, 2008 06:33 AM
