Making the car shift better.
I'd like to get a better feel. And avoid soild motor mounts because i'm using stock ecu and i've herd a no b/s car + solid mounts can cause false knock.
you get the bushings off lancershop? are you using stock shifter?
--Metal or poly shifter cage bushings - good.
--Front lower motor mount - good. Not a lot of vibrations at idle. Great for WOT, hight RPM shifts.
--Shifter fork bushings. Also will help the smoothness/direct feeling.
--Fluids - fluids have a lot to do with how notchy the trans can feel. Amsoil makes a great fluid. Been running it for 40k+ now.
--Shifter knob - I have the Greddy Counterweight. I dont think it changes the speed. But the shifter has a good feel to it.
My shifts are crisp and clean now - no slack or lots of play.
I was having alot of trouble with kind of notchy shifts and things just didn't feel as smooth and pricise as they used to. I installed a ss braided clutch line just because it was something i have been wanting to do. When putting the line in i noticed quite a bit of air bubbles in the stock line. I put the braided line on and took out the restrictor pill and blead the line. After shifts were much better! almost night and day. I would start there its a very cheap mod I got it off lancershop for like 30 buck. A great mod!!!!!! I would start there or altleast bleeding your stock line, you could have air in yours too
i too have noticed some very notchy shifting and a feeling when i go from first to second that is almost a crunchy feeling when i get into second gear. It only happens occasionally but it is still bothersome. any ideas? I just had my fluids changed 4000 miles ago. Tranny, t-case, and rear diff.
I also have VERY notchy shift from 1st to 2nd, and somewhat notchy from 3rd to 4th. My 2nd to 3rd shift is money for some reason - I wish they were all like that.
If I deliberately shift through the notchy areas without pausing, i can feel/hear the synchros grinding...
I would really love to be able to shift 1st to 2nd hard, without pausing midway.
I don't think motor mounts have anything to do with it - it is notchy even at 1500rpm going through parking lots...
My IX has shifter poorly since new. Honestly, I never liked the feel. I went with the following, and it is 10 times better.
-Agency Power underhood bushings
-Ebay shifter base bushings
-BLOX roll stopper mount
-Stainless braided clutch line w/pill removal
The BLOX roll stopper is what totally eliminated my 1-2 "crunch".
Definitely a big for these mods.
Exact same thing as you man. Its our clutch
I'm gonna try some diff fuild, bushings, and clutch line. See what happens
