Evo 4 and Evo 8 differences
Old Oct 22, 2008, 11:27 AM
94AWDcoupe's Avatar
Originally Posted by MaD_CaNaBiCe
ok i have a new problem now I just found out the bottom end of the motor isn't any good but i have a option of getting a eclipse 2.4 bottom end due to the fact it damged the crankshaft bearings so what i will do is get that and bolt the evo 4 head on it what do you guys think? also does the evo transmission have the same bellhousing as the 4g64?
you cant run more than 5 psi boost on non-turbo pistons.
Old Oct 22, 2008, 01:23 PM
MaD_CaNaBiCe's Avatar
well i realise that maybe 8 psi will the max that i can run but i really know if anyone knows if the evo tanny will bolt up to the 4g64 block? and does anyone know where i can locate turbo pistons for the 4g64 or will the evo stroker pistons work?
Old Oct 22, 2008, 01:48 PM
crcain's Avatar
I use a 4G64 with a Evo 8 tranny on my Evo 6. I did not build the motor but I think the block was from a late model N/A Eclipse. If you do a search you should be able to find out what 4G64 blocks are compatible. Maybe all I'm not too sure on specifics. But yes it is all the same block as a 4G63 minus a few things like water pump setup and alternator bracket issues which are easily solved.
Old Oct 22, 2008, 01:52 PM
ok but what about pistons and rods?
Old Oct 22, 2008, 01:56 PM
crcain's Avatar
I don't know a lot about that. I'm pretty sure I run off the shelf evo stroker pistons and then a custom longer rod but not sure.
I would email Norris Designs who do a lot of high deck (4G64) builds lately.
Old Oct 23, 2008, 07:26 PM
ok pm me if you get any ifo on this please thanks!!!
Old Nov 13, 2008, 08:17 PM
Juan Martinez's Avatar
Ok, you can use the bottom end of the 4g64 as long as you use low compression pistons. You'll have to rebuild. Yes, it will mate up the the 4g63 transmission. Some evo owners build the 4g64 and make a 2.4 evo motor out of it.
chaosad
Dec 2, 2009 07:45 PM
Kelkek
Dec 22, 2008 07:25 PM
SlamDunk
Jul 24, 2007 05:14 PM
EclipsePI
Jun 20, 2006 09:17 PM
10secEvo
54
Apr 10, 2005 05:03 PM
Quick Reply: Evo 4 and Evo 8 differences
