Larger FMIC+winter temperature+same tune=lean condition?
Picking up a larger FMIC to replace the stocker. I was just curious if I went ahead and put it on, would the car lean out due to the colder, winter temperatures? I am not getting another tune until spring when the new snail goes in. If I run the new intercooler without any changes to my tune, will I have problems?
Look for the Tephra Mod. Just follow the directions. Like mentioned you should be fine. It may lean you out a bit, but if it really worries you turn the boost down. I normally have to do this every winter anyways.
smgevo
Nov 15, 2008 03:11 PM
