FP Red or 30r?
FP Red or 30r?
im really curious to know if i should go with the FP Red turbo or a 30r? my mods are : Injen Upper/Lower IC pipes, TurboXS FMIC, Forge mbc, HKS carbon ti exhaust, HKS test pipe, Greddy rs bov, BC 272/272's, Walbro 255 fp, ACT hd clutch/flywheel... right now im making 330whp/324tq @ 24psi...
i also have these parts in my garage waiting to be installed... im waiting to choose a turbo first and doing this project over the winter when the car is in the garage: MR manifold, Invidia o2 housing, ams fuel rail, ams 1000cc injectors, BC springs/retainers, HKS cam gears...
how much whp/tq do you think i would be able to make with a FP Red using all those mods and being on a stock block? also would i need anything else to run a larger turbo other than what i have? i heard i would need a double pumper setup but not sure...
could really use some opinions on this, this would be my 1st build i have ever done... btw i have an 03' evo VIII
do an fp red, they are bigger then a 30r and bolt on, its between the size of a 30r and a 35r its spools alot faster, just ordered mine yesterday, good track turbo as well
import junky: 1st off i posted in the newbie section by accident... why would i ask noobs about which turbo i should get when most of those guys just upgraded from POS honda's?
hella jdm yo: my bad i didnt see your thread when i was looking for answers so i decided to ask myself...
has anyone else had the same setup that i would be using? i was told to go 2.3 kit if i was going to use the red, or just jump to a 35r and stay stock block i would be able to push 460-500 safely...
if u stroke the motor u loose a lil top end go with a fp red and a built 2.0 lt
Last edited by cosworthevo1133; Oct 24, 2008 at 01:16 PM. Reason: put the wrong size of turbo in the reply
