Why are people still upgrading to injectors under 1000cc?
Old Oct 26, 2008, 08:25 AM
EVO8LTW's Avatar
I see thread after thread on here where people are debating whether they "need" to go bigger than 780s, bigger than 880s, etc.
Why is anyone contemplating going with smaller than 1000cc when the 1000s work with ease on the stock ECU these days?
I upgraded to 1050s and the car runs exactly the same as it did before with stock injectors and 660s.
I see no point in anyone getting 780s or 880s.
Old Oct 26, 2008, 08:28 AM
ONRAILS's Avatar
why take a 50 cal mouse hunting?
Old Oct 26, 2008, 08:33 AM
fugiwara's Avatar
You've got a good point, that's why you see a lot of people trying to sell their injectors under 1000cc. the reason is b/c back then 1000cc injector don't work well with stock ecu.
btw what kind of injectors do you have, do you know if 1200cc injectors will work well with stock ecu?
Old Oct 26, 2008, 08:56 AM
Ev0cRaZy's Avatar
1200cc Injectors will work fine with a good tuner
Old Oct 26, 2008, 08:58 AM
TURBevO8's Avatar
This is all good news for the consumer. If you really only need 780s, 880s, etc., then you should have no problem finding some used ones cheap as everyone upgrades to 1000 or higher.
Old Oct 26, 2008, 09:35 AM
Nissan2Evo's Avatar
I'll have some PTE 880's up for sale soon. On my old setup, GT3065/meth with the 880s, we were seeing 70% IDC's @ 30psi of boost. Plenty of injector headroom left even if were to take out the meth injection.
Old Oct 26, 2008, 09:50 AM
EVO8LTW's Avatar
Because you have room to grow and there's no downside as far as I can tell. Why buy twice?
For the person that asked, mine are FIC 1050s. And this is not a matter of having some guru tuning your car to make the impossible work. I installed these myself and used the scaling information that I found in the EcuFlash forum. Trims, cold start, etc. are fine.
Old Oct 26, 2008, 09:57 AM
BiFfMaN's Avatar
880's were fine for my 50 trim. Easy to tune and Idled fine.
...BUT, i think a few people has gotten the E85 Bug and require bigger injectors. Because I too just upgraded to 1200cc injectors.
Old Oct 26, 2008, 09:59 AM
Matthew333's Avatar
if 880's were enough why go larger.. I had a 30r w/ 880's, got a 35r, and finally a 37r- then upgraded to larger injectors. You think you need 1050's with a fp green, or red??? I dont. I think the smaller injectors can be easier to tune.
Old Oct 26, 2008, 10:06 AM
EVO8LTW's Avatar
I think it's a myth that the larger ones are harder to tune. Seriously, I dropped these in, changed a few values in EcuFlash, and they run like stock. I have 280 cams as well, and the idle and start-up are just as good as before.
Old Oct 27, 2008, 01:15 PM
deuce329's Avatar
Buschur sold me on 780cc when i wanted 1000cc for my RED. They talked me out of the 1000cc saying they were to big for stock ecu. I really regret the decision to listen to that b/c now i have to spend money to get bigger ones!!!
Old Oct 27, 2008, 01:38 PM
bchappy's Avatar
^ and this is why we dont listen to people who want to sell EMS's for tuning larger injectors
Old Oct 27, 2008, 05:51 PM
I4UnderPressure's Avatar
Off topic but what size would you guys recommend for an E-85 conversion?
Old Oct 27, 2008, 05:56 PM
beemerfreak's Avatar
I think u have to run 1000cc or higher.
Old Oct 27, 2008, 05:58 PM
Import Junky's Avatar
I remember reading your thread and deciding on 950cc injectors because I have pretty much the exact same setup as you. I talk to Sean and told him what I had and he said they would be good.
Quick Reply: Why are people still upgrading to injectors under 1000cc?
