My review of the Exedy Twin Plate
Originally posted by Z1 Performance
Shape - the Exedy Hyper Single and Twin Disks are all spring hub (so is Cusco, since it is for all intents and purposes an Exedy), as well as Power Enterprise (also an exedy for all intents and purposes); s is the new GD Max clutch from HKS
The GD Pro from HKS as well as the triple disk clutches from Exedy/Cusco, PE are solid hub, hence quite nasty engagement, but great for the uber high HP cars and unmatched grip.
Ken if you can swing buy and take me for a drive I'll let you know the deal - sounds normal though from your description
Adam
Adam
Ken
I drove Nastea's car with Exedy twin-plate. Very precise engagement, but you could feel how it easy it would be to slip it. I am sure it would make for outstanding launches. I didn't go too hard on it since it was still pretty new, but I was very impressed. There was very little chatter and the engagement was direct, but not enough to make the car pogo when driving off from a stop.
We've had a lot of luck with the Exedy Twin Plates. Our customers do complain of more drivetrain noise, and in some cases slight vibration, but overall are very pleased. What you are experiencing is completely normal. The engagement is awesome on these clutches.
We do stock these, and have out 3 units left. They do go quickly though. We're also offering a 20% off coupon code. Sorry, shameless plug
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
In my experience, the whine that some have heard is likely the normal decel noise accompanied by an awd car with a multi-disc clutch. If you are unsure about your fluids, then check them
![Wink](https://www.evolutionm.net/forums/images/smilies/wink.gif)
I have the Exedy Hyper single disc also & it's annoying as Sh*t, it rattles when decelerating....i hate it!
Hooks good though, but i'm sure they're other clutches that'll do the same & make less noise.
How is the clutch life longevity in a twin disc compared to a single disc ? Would the twin disc last longer ?
Also, how would you know for sure if your clutch is starting to go bad ?
The carbon plates are more durable and less prone to problems from slipping. If you plan on drag-racing the car, carbon/carbon is the way to go. I am pretty sympathetic mechanically and I don't drag race, so a carbon/carbon clutch should last me a LONG time...
bbong
Jun 11, 2017 05:25 AM
Protostar1
29
Aug 3, 2011 04:31 PM
rice_rocket88
17
Oct 27, 2007 05:00 PM
