Info on turbo upgrade people running "4088R" Chim in plz ;)
Old Nov 12, 2008, 09:17 AM
Magnumpsi's Avatar
4088R on a DNP Manifold. This is at 33psi.
I am a huge fan of this turbo. The full race setup on this would be the ultimate.
I say go for it Sharkbite
Mitch M
Old Nov 12, 2008, 09:40 AM
andreww238's Avatar
damn shark.. seems like you just got the 850r, is it on its way out?
Old Nov 12, 2008, 10:12 AM
ScorpionT's Avatar
The power that DSMer made on a 4088 is VERY impressive, because the turbo is rated for ~700hp. I think a good upgrade would be something like the HTA 37R/T04Z because it should do better than a 4088, and you could keep your T3 manifold.
Old Nov 12, 2008, 11:49 AM
Sharkbite2000's Avatar
Mitch M
That's alot of lag is that must be 2.0 set-up , I've seen other dyno's with a 2.3 that spools up alot faster like in the 4000's rpm range.
Old Nov 12, 2008, 11:51 AM
Whoop_ass's Avatar
I am running Full race stup on a 2.3.
I don't think you will make outright more power with a 4088, but one thing is for sure it will out spool and be a better drivers car than the 850r.
I get 22psi at 4100 rpm with FR kit and GSC S2 cams.
and i am 5500ft above sea level.
the 4088 spools as quick as my AMS 30r setup as on a 2L
Magnumpsi's Avatar
This is at 5000+ feet lol. And it is a 2.3
I have some more sheets but it really is not that late to spool. It also is not a true TS setup.
Mitch
Old Nov 12, 2008, 11:54 AM
I'm looking to try something else that I don't have to crank it up to 40+psi to feel the power, but then again ,I'm not normal I crave HP all the time.
Old Nov 12, 2008, 11:57 AM
Nice ride you got there I was checking out your ride very nice. Do you have a dyno sheet of your car ?
Have you ever looked at the 4094?
Old Nov 12, 2008, 12:02 PM
Whoop_ass's Avatar
here check this out
I have posted on another thread some where else.
3rd Gear 4600rpm.
this is at 5500ft above sea level
altitude is a killer.
but like i said before I dont think you will make much more top end power with a 4088, but you will def have more area under the graph.
Old Nov 12, 2008, 12:05 PM
dsmbruno's Avatar
What is the purpose of the car? Do you just want good whp numbers or good 1/4 mile #'s? Size doesn't always matter as you see people with stock framed turbos running the same times as people with 35/37r's. You should ask the "dude" where you have your car what he has to say...
Im sure you know: WHP= the bigger the better, while good 1/4 is a compromise between lag/weight/whp/wtq
Old Nov 12, 2008, 12:10 PM
Whoop_ass's Avatar
Thanks very much.
I should have figures by next week some time, havent got around to tune the car.
was on the dyno a week ago just to check if all is ok and we not having any probs
car did just a smidge over 500hp @ 1.6 bar boost, this is actuator boost.
we ran 4 deg on peak torque and 8 at 7000.
I don't have the dyno sheet but will ask the guy if he could dig it out.
this was on a dyno pack dyno.
there is way more in it with more timing, and then i will crank it up to 40 PSI with race gas.
Old Nov 12, 2008, 01:56 PM
Have to wait and see I'm still turbo shopping keeping the A/C is a must in my set-up.
Old Nov 12, 2008, 02:01 PM
1NastyMR's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=380322 there u go sharkbite 804 650 tq probably on a 2.0. I don't think your gonna get the power u want on a 2.3 seeing u cant rev up the turbo as high which is actually the whole point of a big turbo to take it higher rpms to make power.
Old Nov 12, 2008, 02:14 PM
ONRAILS's Avatar
9000rpm isnt enough?
Hes already had a 37r for a long time guys. Why would he want another to4z?
If your really wanting power, i'd go twin scroll T4 4094! also the 4088's do great on scoobies
they don't run near the boost we do. I really don't think i've seen any 4088 dyno numbers above
33psi. You could make the same power you are at 42 @ 31psi with the right manifold and correct
exhaust housing on the 2.3L you will end up with a very nice setup and same power at lower boost
if thats what your looking for!
Old Nov 12, 2008, 02:17 PM
I might have to destroke it and see how that run's but before I do anything I just wanna get enough info to go the right direction. I never liked the 2.3 ever.
Quick Reply: Info on turbo upgrade people running "4088R" Chim in plz ;)
