Info on turbo upgrade people running "4088R" Chim in plz ;)
#31
9000rpm isnt enough?
Hes already had a 37r for a long time guys. Why would he want another to4z?
If your really wanting power, i'd go twin scroll T4 4094! also the 4088's do great on scoobies
they don't run near the boost we do. I really don't think i've seen any 4088 dyno numbers above
33psi. You could make the same power you are at 42 @ 31psi with the right manifold and correct
exhaust housing on the 2.3L you will end up with a very nice setup and same power at lower boost
if thats what your looking for!
Bingo someone that finally understands what I want
I've been looking on data on the 4094 but haven't found much.
#32
Sharkbite hit up Tony. His Aim name is MilkMe131.
He has a 2g. He went 9.9 at 32psi with the 4094r using dsmlink . It hauls.
Edit: Here is a pic of the car now but I believe the 9.9 was done with the 4094 and a standard 5sp tranny.
http://www.extremepsi.com/store/cust....php?pageid=20
-Remy
-Remy
#33
https://www.evolutionm.net/forums/sh...d.php?t=329043
I think the 4094 will be your answer if you want something that big. Turbine side like a 4088, so it wont choke out at higher RPM, compressor better than a 37R for more overall power.
#35
If I could find the dyno sheet's now on how it spools and where it's making the power.
#42
Some of us like to have speed and style at the same time. Im with Sharkbite I have a sub, two amps and a whole bunch of other extras in my car, I wanna be able to kick *** and be FULL+ weight.
#43
Just removing weight from the car will make the car go a few tenths faster. What are you trying to do go faster 1/4 or you just want more hp. If its more hp then ya a bigger turbo will be needed
