Info on turbo upgrade people running "4088R" Chim in plz ;)
#64
yeah that is the 4094... honestly on the street i hate it since it is so lazy but i just dealt with it. i would get full boost around 5500-6000 on a 2.2 that i had. i only got to 450hp because i never got to complete my fuel system and then spun the motor again so i am currently putting in a buschur 2.0 built block and will get all the dyno graphs. hopefully it should be done within the next two weeks since i am so busy with school and working on it myself.
#66
#67
#68
So after seeing this thread and the other 4088 thread I am interested. I have a couple of questions.
If I have a 2.3 stroker kit with the 4088 1.06 A/R and the crank has been knife edged and balanced/polished and I also get the lightened drive shaft that a vendo sells on here would that help with the spool up even more? Since I am reducing rotational mass in two areas. Could i spool up even faster than having the stock parts (drive shaft and non knifedge crank)
#70
#71
#72
i am going to do that i currently go the new magnus cast aluminum intake manifold so i going to redo my cold side piping and while at it make a pipe for the intake and also got a new radiator with ss lines to make it look cleaner
#73
#74
#75
