clutch slipping
clutch slipping
Ok heres the deal. To be short, just had transfer case rebuilt do to a mechanic error from my last clutch job. Then i had the transmission rebuilt because it was starteing to go out. anyways i have an exedy twin plate clutch in it now and it feels like its starting to slip. I hope this isnt the case since it only has about 12k miles on it and this is my 2nd exedy twin installed. When the transmission was out, the mechanic viewed it and said it looked like it had plenty on life left in it and it wasnt really worn. This was only visual inspection, he did not take a closer look at it. right now the clutch doesnt grab until it is almost all the way out, typical exedy will grab after only 2 inches or so, not the whole way. Im not one of those who are rough on their cars, i dont launch it nor ever have, i dont burnout, shift incorrectly, or anything like that. So with the wear on the pads being fine, what could be causing the clutch to feel like it is slipping. Some thoughts ive heard so far are
1. pressure plate malfunction (heard highly unlikely)
2. clutch discs themselves went bad(also rare but can happen due to bad shifting)
3. clutch itself installed incorrectly. (but worked fine the first 10k miles or so)
im at the point where im about to get my car back for the first time in over a year, and the costs i have incurred are great with the trans and tcase. im trying to avoid the 700 price of tearing out the clutch and putting it back in to see what the problem is, and if i truly had to pull it out to begin with.
Any expert advice you guys can give would be great. thanks!
o sorry, yea forgot to mention. I did have the clutch try to be adjusted no luck. I havent had the car on a dry enough road yet to test to see if it spins out. its too wet right now
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
Harumsevo
19
Aug 10, 2013 12:26 PM
undressesitself
Sep 9, 2012 08:48 PM
mxguy1286
14
Sep 15, 2010 07:09 PM
