Where did my EVO 8's coolant go? Bottle always near empty???
Old Nov 13, 2008, 05:25 PM
Blue Evo 8's Avatar
I just noticed just within the last week my car has been consuming a lot of coolant. I would fill it up the the max mark, then go for a drive, park the car and come back to find that the coolant bottle is near empty??
What gives?
I dont see any leaks, no smoking, and my oil is free from coolant, and the car makes tons of power w/o any problem??
Old Nov 13, 2008, 05:54 PM
1d10t's Avatar
Do u have an OE radiator?
Old Nov 13, 2008, 06:01 PM
Evoryder's Avatar
It's going somewhere...trust me.
Old Nov 13, 2008, 06:08 PM
Blue Evo 8's Avatar
Yes, its OEM
But where is what i'm trying to find out....
Old Nov 13, 2008, 06:39 PM
Evoryder's Avatar
Originally Posted by Blue Evo 8
Yes, its OEM
No cracked piping? You jacked up the car yet? Or you looking from up top?
Old Nov 13, 2008, 06:41 PM
Blue Evo 8's Avatar
I'm looking from up top right now.....everything looks kosher....
I look on the floor of my garage and dont see any leaks
I'll have to jack up the car once it gets dry out....
Old Nov 13, 2008, 06:42 PM
red evo8's Avatar
oem radiator cap?, if not theres you culprit.
Old Nov 13, 2008, 06:45 PM
phenaly's Avatar
Check everywhere...get under the car and inspect all hoses/radiator/head/water pump/etc.. If you can't find anything get a cooling system pressure test done, you'll have to go somewhere or buy the tool kit. Check to see if you're losing pressure then inspect for leaks.
Old Nov 13, 2008, 06:53 PM
Jeffs2006EVOIX's Avatar
your post
Its normal for some coolant to dissapear, but not that much, could be a blown head gasket, but depends on where its blown will depend if you notice it or not. Is the car heating up at all? Even if it doesn't could mean that it needs to be pushed but just driving around town? How about a crack in your coolant resivour? haha. You never know.
Old Nov 13, 2008, 07:03 PM
Blue Evo 8's Avatar
No, I'm using the greddy radiator cap...
but I'm using the OEM Thermostat though....
comments??
Old Nov 13, 2008, 07:05 PM
Blue Evo 8's Avatar
The car heats up to normal operating temperatures just fine.....
crack in my coolant resevoir? possible, I'll have to check, but I highly doubt it.
Old Nov 13, 2008, 07:10 PM
markymark1082's Avatar
Go back to your OEM radiator cap and see what happens.
Old Nov 13, 2008, 07:14 PM
wevo1985's Avatar
how old is your waterpump. its possible that could be leaking out the wheep valve and you dont even notice it.
Evolution IVGSR's Avatar
My car does the same thing too???? No leaks and I have a Koyo radiator and everything looks fine? I fill bottle up twice in the last 6 months but No leak... nothing??? And mine has been empty for the last 2 weeks and the radiator is still topped off just the bottle goes empty??? Really what gives? does this thing still have air pockets in it or do it just drink the stuff?
Old Nov 13, 2008, 07:15 PM
Blue Evo 8's Avatar
my water pump is as old as the car, and the car is a 2005 model.....
The car only has 18,000 miles on it.
I'm in the same boat as you sir
Quick Reply: Where did my EVO 8's coolant go? Bottle always near empty???
