My build 03 Ly Evo w/pics.
ams fuel rail
gates racing serp/timing belt
hks dli2
jm fabrication *drag* intake manifold
ku engineering tb
buschur racing motor mounts
rc 1200cc injectors
tial 50mm bov
other parts that i have purchased but have no pics yet are:
Buschur Race Fmic
Br Spec head/shortblock
Br Double Pumper
Exterior/susp
jdm evo 9 front bumper
tein flex coilovers
aspec rear strut bar
godspeed f/r sway bar
ams fuel rail
hks dli2
ku engineering tb
rc 1200cc injectors
tial 50mm bov
Buschur Race Fmic
Br Double Pumper
Exterior/susp
tein flex coilovers
Constant high rpm's will do it, crappy mitsubishi rod bolts i know alot of people think the evo's have a solid motor but there not, i only had around est 380 on pump gas and this happend. Im pretty sure the rod bolts/bearings are a problem when you get to a certain hp level with factory parts.
Originally Posted by yellowevo82
How long till you get the motor put back together etc etc.
I think it was a combination of things, I helped Brian take the head off the car and this block/head was shredded. For one, 30psi from the stock turbo didn't help it much, and neither did the 8500 redline on stock valves and springs, or the rod knock from leaking out all the oil from the old broken return line off the turbo. The rod knock is what caused it all, rod broke, headgasket popped, stock sodium filled valves as they break + engine coolant = nice explosions which was caused by the shredding timing belt. In all honesty I think all this could've been avoided if you'd taken my advice back in January about the rod knock. But hey, ya gotta learn somehow!
i hope this doesnt happen to me!! I have a new Stock Short Block just put it in about 2500 miles ago and i just installed the FP red turbo with cams. Im scared!
All things happen for a reason. Good Luck man.
