low end power
Other than what been mentioned so far, up the boost a little bit, and thats about it. You wont get much low end grunt from a 2.0 beast. If you really want to spend the money, get a stroker.
Lowend Torque can be had but most of the time with a cost in HP. The stock turbo, increased scavaging with duration, and some added boost is an easy route. At 27+psi there should be enough to consitantly break traction when boost hits but it won't make squat for HP and you'll have reversion up top.
