ENGINE VIBRATES when clutch engages???
your flywheel is probably warped or has hot spots from slipping the clutch. it's annoying but i would just wait until the clutch needs replacing to resurface the flywheel or upgrade.
Compared to my old 180 SX or other turbocharged cars i've driven the Evo is by far the smoothest and easiest to drive.
Sounds like crankwalk! lol
I don't mean to be an ******* but are you applying the throttle while "not slipping the clutch" because from your description it sounds like you're just letting off the clutch too quickly without applying enough gas.
That'll cause any 4 cyl engine to vibrate/stutter.
bbong
Jun 11, 2017 05:25 AM
