What Is my best option in my Situation.
Hey Guys,
I have and '06 MR and after a launch yesterday my clutch started to slip . I have a small dilema now because i have heard that the 6 spds are know to go. I wanted to go with a ACT Heavy Duty, StreetLite Flywheel and a Full disc Combo..Also i have the Buschur Under the hood bushings and i m planning to go with the Works shortshifter.. My question isam i wasting my time with thw 6spd? I Dont plan on going over 400whp
Is the clutch Kit Good?
I dont normally drive the car HARD once in a while Dragstrip and those street races in MEXICO once in a blue moon..
Hey Guys,
Do you want to replace your tranny, or would you rather replace your clutch, perform proper maintence and enjoy saving a bunch of money? Having a built 5 speed doesn't mean you can drive like an asshat and have everything be fine. Also, having a 6 speed doesn't mean your tranny and t-case will explode the first time you sneeze at it. Buy what you fell is appropriate for your driving style, but whatever you do, perform regular fluid changes.
Well so far since i got the car I raced in Mexico maybe 6-7 times.. I want to take the car to the Drag Strip and to a Road Course at least once just for the expiriance. I just did The whole fluid change in the car including T-case, Tranny, Read Diff. and Motor. and i plan on keeping up with all my routine Maintnance. (I've had the car abour 4 months)
My plans for the car Preformance wise are as follows:
Buschur Intake
Buschur TBE
Buschur o2 Housing
ETS Intercooler Kit with UICP & LICP
I havent decided what cams to go with yet.
Forge Manual Boost Controller
Walboro 225 Fuel Pump
Ivey Tuned.. around 23psi
Buschur Intake
Buschur TBE
Buschur o2 Housing
I have an 06 MR and I love it. The 6-speeds are known to be a little weaker because you are cramming more gear in the same amount of space meaning they have to be a little smaller, but they aren't "weak". Yes, obviously beating your car to a pulp all the time you will break something without a doubt, but under 400hp you should be just fine. I make in the mid 300's and I race my car at the track and in Mexico quite a bit, haha. Never had any problems and I'm at about 50k miles. Only suggestion is, I have heard rumors of ACT clutches being problematic as far as locking out and breaking your tranny, so to avoid any of that, go with a clutchmasters.
To the OP:
You'll be fine with the 6 speed as long as you are not road racing. As far as the WORKS short throw shifter is concerned; you are aware only an authorized WORKS dealer can preform the install right?
Without monster horsepower I doubt you'll break it drag racing. Warrtalon was the perfect example, I think he had 200+ passes on his 6 speed prior to going to a 5 speed.
Road racing is another story.
Thanks for the opinions guys. I know about the works short shifter. Prefomance Motorsports on LI will do it, thay charge like $320 for the shifter and the install.
Also i was looking at a number of clutches for the car but none of the specify the clutch being for the MR
Destin_sinner
58
Jun 10, 2010 08:18 PM
boostincincy
Aug 29, 2008 05:33 AM
fastassfourdoor
Jun 14, 2006 08:51 PM
