Will a standard OBD-II scan tool pull ABS codes?
just as the title implies. im wanting to know if a OBD-II / Controller Area Network scanner can be used as an ABS code scan tool as well.. thanks in advance!!
Registered User
if u got an ABS problem, your ABS light will come on.
i don't know of any program to read the code though!
but the ABS should be a simple system to diagnose the old fashion way of inspecting by eye, what problem u got?
a regular obdII scanner does not read abs codes - i had an abs code on last year and tried like 4 different scanners and none of them worked - try cleaning all your abs sensors on the wheel hubs - brake cleaner does the trick for it
