Misfire with CDI COP system..
I am looking for any ideas as to why my car is misfiring. When I have my stock coils on my car I can run 20-22 psi all the way to redline. When I swap to my new CDI COP system, I get misfires from 7k to 8.4k same boost and same tune. Ive reinstalled the system and reseated the coils several times, checked the springs, checked the boots. I also checked all the connectors, reconnected power and ground.
I have a track event this Saturday and I'm trying to run more than 26-27 psi that I ran last time. I thought this ignition would resolve that issue, however, its only made it worse.
explain what was going previous to switching to the COP.. If you were getting a misfire at 26-27 psi before the COP you have an issue.. Did you have a DLI on when you were getting misfires after 27psi?? I ran 37psi w/o misfire on DLI..
Mike
Mike
I was runing the stock ignition on race gas at 26-27 psi at the track and anything above that I would start to misfire. On pump gas (91 oct) I was able to run 23 psi before the ignition would break up. I swapped over to my new CDI COP system and on pump gas I am running 20psi and the ignition is breaking up. No boost leaks, new plugs. I switched back to my stock ignition a few minutes ago and the car can handle 23psi with not misfires.
I used to have the same issues and ended breaking a piston , when i took the engine apart i had a clogged injector, it flowed 23% less.
Edit**
Mike
Yeah, switching to the stock coil and resolving the misfire would eliminate the injectors. It has to be the new COP system. I just need to figure out were I am going wrong with the install or maybe just a bad coil.
Stock coils are running perfect up to 23-24 just like always. Logs confirm not one misfire. I did quite a few pulls to confirm this. Also I dont feel any misfire with the finely tuned butt dyno haha, JK. Thanks so much for the responses :P. I have work tonight and I skipped sleep to try and figure out how to fix this for the track on Saturday. I was so pumped cause I got my traction issues under control (BFG drags) and I thought I had my ignition issues resolved...
