The official 6-speed failure thread
Old Dec 8, 2008 | 04:01 PM
  #31
berns's Avatar
2nd Owner (first owner had a tune, exhaust, intake and mbc)
38,000 miles, brand new stock clutch and pressure plate, stock everything aside from shifter bushings and an mbc.
Issues: notchy 2nd gear, 4th gear grinds on fast/redline shifts, and 5th gear lockout when shifting fast into 5th from the top of 4th.
Old Dec 8, 2008 | 04:21 PM
  #32
Erik@MIL.SPEC's Avatar
Anyone else like me have almost 100,000 miles on their 6 speed without issues?
Old Dec 8, 2008 | 04:22 PM
  #33
MR Dan's Avatar
MR DAN
Evo 9 MR
15,200 Miles
Stock clutch
~300WHP
11 track events with factory tranny fluid change prior to any event
Currently car is at the dealer due to failed mainshaft bearing
^^ The sound is like having a dog-box tranny
Old Dec 8, 2008 | 05:15 PM
  #34
HyaboostaIX's Avatar
HyaBoostaIX, 46,000 miles, Minor bolt-ons, approx 310whp, A little notchy in 2nd...but only sometimes when it feels like it. Other times it shifts smooth as butter. Other than that, perfect. Still have to change fluid to see if it helps. Occasional Drag, spirited Driving
Old Dec 8, 2008 | 05:25 PM
  #35
Clutchdc5's Avatar
sorry DP
Old Dec 13, 2008 | 11:15 AM
  #36
Blitz's Avatar
Originally Posted by EvoJoeIX
i dont consider a grind a failure. a failure should be classified as the car is unable to be driven
This is a good point. I'll change the list unless anyone thinks I should include grinds.
Old Dec 13, 2008 | 03:43 PM
  #37
SRT-TO-EVO's Avatar
Smooth as butter here (although notchy when cold out, not warmed up). 340WHP, 10,000 miles.
Old Dec 15, 2008 | 01:01 AM
  #38
jxs1984's Avatar
300 to 350whp range seems to be popular for the MR
Old Dec 15, 2008 | 01:16 AM
  #39
bigruru's Avatar
im the 3rd owner and my car has 26,500 miles on it and i have a act 6puck race clutch but my tranny is a little notchy at a stop in 1st and notchy in second when it feels like it, it scratches 3rd and 4th every once in a while do to the syncros but yea other than that it runs good!
Old Dec 15, 2008 | 03:12 AM
  #40
smack_evo's Avatar
smack
ix mr
note: before i bought the ix i had a 03(5-speed obviously) that i had about 30+ trackdays on with no problems at all at the same tracks.
first failure was at 850 miles at thunderhill(local road racing track) about 15 minutes into the first session of the day. stock clutch and power.
heated up 3-4 slider and it bound up on the gears so it locked you out of 3rd and 4th.(same as voidhawk) here's a pic(credit voidhawk) of a cooked 6-speed 3-4 slider vs. a 5-speed one with much heavier wall thickness. as you can see there is about half the material so it just can't handle the heat and starts to warp, thus binding instead of sliding over the gears.
trans repaired under warranty.
the thought from the dealer was that the trans might not have been broken in enough so i ran the repaired one for 5k miles and then took the car to laguna seca.
same failure again on the last session of the day. still stock clutch and power.
trans repaired again under warranty and then promptly voided
so i swapped a shep 5-speed in and then ran the next two seasons of nasa time trials with about 360whp on a exedy twin plate and now 425whp on an act clutch and haven't had a single problem.
Old Dec 15, 2008 | 05:13 AM
  #41
kiley_sean's Avatar
Kiley_sean - 48,000 miles - 300whp 300wtq - TONs of autox and drag racing - 1st and 2nd gear are notchy when cold..but it's done that since new.
Old Dec 15, 2008 | 05:21 AM
  #42
sblvro's Avatar
notchy when cold , grinding are not tranny failures. have 30k on my stock IX MR with no tranny issues whatsoever.
Old Dec 15, 2008 | 10:54 AM
  #43
JDMevoBOOST's Avatar
No Major probs here minus the 1st to second hiccup (not smooth going in 50% of time), but I hear that it's pretty normal.
19,000 miles - 330whp/300wtq (GST mustang dyno) - fluid changed at 1K and 12K - completely stock drivetrain - 100% street duty
Iowa999
170
Mar 10, 2020 07:05 AM
PIE-R
Dec 21, 2019 09:14 PM
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 03:54 PM
92gsxbaltimore
10
Sep 6, 2008 05:02 PM
marksae
Oct 17, 2007 02:52 PM
