XEDE vs eManage vs Works Reflash
#47
For 430.00 the emanage appears to be a very good deal. It is also very versatile. I need to look more into it because it's about half the price of the XEDE with approximately the same functions.
#48
so.. XEDE is double the price of eManage... but XEDE controls
boost as well... for eManage to control boost, you'll need to buy
additional controller (Profec e01)??
#49
Anyone know the limits of the stock boost solenoid? I'd like to know how many lbs of boost can be programmed by the XEDE.
#50
Shiv
#51
I am have been using the emange on my car and made up to 557 wheel hp with it - its a great set up and has a lot of extra functions - BUT it is something that requires a dyno and a very good understanding of tuning to use effectively and safely
I have switched over to the dyno flash system 100% and soon we will see just how much power the evo can make on the stock ecu and a re-flash
Personally - I like the idea of the HKS EVC V stepping motor to control my boost MUCH more than the cheap stock boost solinoid - - so far we have yet to see a boost controller which performs like the new HKS solinoid - so for me - I like a reflash and the HKS EBC
#52
I love the all functions in one box concept that is the XEDE. The ONLY thing that has stopped me is that I just can't afford one quite yet.
I like that you can DL good maps to start with, whereas the emanage really needs dyno time (read: expensive) and also good boost controller (expensive), as I'm done with fussy MBCs that change boost levels when the weather changes a bit.
But perhaps the best thing about the XEDE is you get product support from the guys at Vishnu! Installation issues, MAP issues, technical questions? Never going to be unanswered. They have always been very courteous and patient with me when resolving issues for my WRX in the past.
Factor all those things in, and the XEDE doesn't look like its that much more expensive at all. IMO, its a great value for all you get, I just have to keep saving!
#53
Originally posted by 909
The AEM standalone sounds really promising. I just have some questions about it. What happens to the imobilizer? And does it use the same air flow sensor? I know one of the main air-flow bottlenecks of the Evo is the air flow sensor. If I were to go with a standalone unit, it has to be one that allows me to do away with the stock air flow sensor. MOTEC so far is the only one that i know of which replaces the stock air flow sensor.
All of the standalones would allow you to get rid of your MAF sensor. The Motec can only run in MAP mode it will not work with the stock MAF without a lot of effort. The Xede can do this also.
The GEMS, Autronic, Pectal, Apexi Power FC all can run either MAP or MAF. The AEM EMS is deisigned by GEMS so there are many similarities between them.
#54
With the e-manage, you can also adjust the scale for both throttle position and rpm. You can adjust the scale down to 100 RPM increments if needed and 1% increments for throttle position. So if you are seeing that no adjustment is needed from 2000 - 3000 RPM all across the TPS range, you can change the scale to start from 3000 RPM up to redline in 250RPM increments if you wanted. What ever you can fit in 16 cells up to redline.
<<snip>>
<<snip>>
mr.almeida
Mar 15, 2010 06:23 PM
Noize
25
Sep 22, 2008 12:59 AM
HiVoltEVO8
49
May 11, 2006 11:50 AM
