Compression check - normal?
Hey guys, I swapped in some new plugs last night and did a compression check at a buddy's place. His IX MR turned up 180 across the board, but mine turned up 140/140/145/140, is that odd? It's consistent at least, but we both have IX's so why would it be so different?
Also, I got a SES light on since I did the compression check and changed the plugs. I used Denso Iridium (IKH22) gapped down to .25, I'm stock, so do I just need to yank the battery cable to reset the ECU and clear that SES light or what?
TIA.
TIA.
TIA.
TIA.
If your numbers are within similar % of each other, its good as more boost is the replacement for compression.
Your numbers are down a bit however, hopefully not due to a worn engine/head.
TIA.
TIA.
Yeah the car was hot, I had driven it to my buddy's house and it say for maybe 10-15 minutes while we were yanking the plugs from both cars. Are you supposed to depress the gas pedal when doing compression check? I just pushed the clutch in and cranked it... first time I've done a compression check.
Throttle plate open or not open..........it really does not matter it just takes a little bit longer to get a reading but the reading will still be the same.
Those #'s look good and don't worry if it stays that way. If it gradually gets less then worry.
The 12cyl dual-turbo Porsche 918 race car from the 70's made 1300HP. It's 7.5 compression ratio allowed longevity. One car retired with over 100,000 race miles on original engine. If your engine is healthy and came that way from the factory, it might be a blessing
Jakeg97
133
Jul 30, 2021 09:19 AM
wiggle1r
May 6, 2005 08:05 PM
