Different sized tires
I had to replace my 2 front tires. I bought a pair from a guy locally. Unfortunately I didn't notice they were 235/40s instead of 45s. I didn't notice this until after they were mounted and now the store is closed. Am I going to damage the tcase/diffs by driving like this? I know this isn't good but it's my dd and will take a couple days before I can it worked out. Thanks.
I wouldn't drive for very long like that! Your front/rear wheels will be spinning at different speeds and your transfer case can only take up so much of the difference before damage occurs.
Inflate the tires with smaller diameter to higher psi. You can mark the wheels while adjusting psi until they all end up at same place after several rotations. Just to get ya through the week til you have a complete set. You'll be suprised on the amt of difference psi has on tire circumference
you should have bought my tires so you wouldnt have this problem! haha just kidding my man. +1 on the different psi, if you are careful and mark the tires properly you should be able to adjust the pressure so it alleviates some of the strain on you t-case. but as you already no its still not great. good luck with getting them all squared away.
for what its worth i got re-o1r's as you know, and love the crap out of them. keeping the mileage down on my car too bc i live in a place where i get a ton of snow, and those arent so good in that aspect.
