Way OVER redline!
Way OVER redline!
I was driving in 4rth gear tonight and at the end of my rpm band i was switching to 5th, Some how, I slipped it into 3rd. It downshifted Hard as **** for less than a second. But i am worried. It sounds normal, runs normal, and nothing is noticeable as far as driving. But i cant sit here and think that nothing has went wrong with the engine.
I have an SAFC and i was running -5% on 7000. I wasn't giving it any gas by the time i shifted into 3rd and the SAFC recorded my peak RPM at 9374 rpm.
and Kar was at 1604 Hz. I am just worried, because i have never done this before. And i was way over redline. I just cant imagine the engine still being ok. Can anyone put a light on this subject, and tell me what kind of damages likely occured.
Thanks,
Marcus
Thanks,
Marcus
WOW! usually will bend valves (caused by valve float). Car seems ok? Idle smoothly etc.? For piece of mind do a leak down test on each of the cylinders and maybe change the oil looking for expensive shiny things. If all is ok count your blessings and don't do it again! I doubt it would survive that too many times...
yea the same thing happened to my friend in his rsx-S.. he was on the track doing around 90 in 3rd, and when he tried to shift to 4th, he missed and jammed it in 2nd. his engine blew up right then and there.. and u wanna kno wut acura saw as his peak rpm from the ecu? 12500 freakin rpms!!! i never even knew that was possible.. story back on topic, u shouldnt really worry about it, because something woulda happened by now.
Thanks for the quick replies. I was scared ****less that i would need a new motor soon. Don't do it often eh? I'll try my best. I guess i can have a posative outlook on this and start a post of who has reached the highest RPM... I am so glad to hear this news.... Thanks alot!
I will for sure, be very careful now, even though i've always babied my evo, but i guess everyone messes up sometimes, and maybe i can blame my shortshifter.
Marcus
Marcus
Originally posted by bobaab
i saw another rsx that did that..shouldnt synchros not let u shift into a lower gear at such high speeds??
Originally posted by Marcus84
so, why didn't it blow up? even though i was running lean?
confuses the hell outta me.
Now, don't do that again!!!
If you bent your valves you'd know it. The car wouldn't act right afterwards and would probably throw a CEL being the emissions is all screwed up. At least that's what happened to my ITR.
I was doing about 80mph and was going to 4th and went to 2nd. The car acted fine til I slowed down to pull into a parking lot and it died right in the middle of on coming traffic. To make a long story short...I ended up driving it home and while on the highway it felt perfectly normal, but as soon as I got off my exit it died and I didn't have any brakes and had to pull the e-brake. It didn't throw a CEL til the drive home.
After it was fixed, I had some more problems with it and it kept throwing CEL's again after about 4-5 months after the fix. Come to find out, some of the valves were bent again, but not bad enough to where it would die. It was throwing a mis fire code and it wouldn't pass emissions that way either.
I'd say your car is fine. I would be more aware and pay more attetion to what gear your going into. If for any reason your car starts to die on you, you probably have some bent valves.
Good Luck!
Good Luck!
