HTA 3582 & 3586 LBS airflow?
what rpm difference would the spool characteristics be for a gt35r- hta35r- hta3586? i was told that you should see increase 150rpm difference in spool going to a hta35 from a gt35r. and you would see a delayed 300 rpm spool difference from a gt35r to a hta3586.
was also told that with a hta35 you would see an average of 15-20 hp difference across the whole rpm range. is the info correct?
An HTA3582 appears to spool about 300rpm quicker than a standard 35R, and it is capable of around 10% greater whp and torque. It's a win-win situation vs. a standard 35R.
IIRC, the HTA3586 spools slightly slower than a 35R, and is good for more power than an HTA3582. If this is accurate, that equates to probably ~500rpm or so difference between both of the 35R variant HTAs.
Both HTA3582 and HTA3586 are 700+whp capable turbos.
