My 4G64 block after machine work *PICS*
Old Jul 7, 2010, 01:06 PM
  #106
lp_ceo's Avatar
Originally Posted by SeanC
I doubt I'll have a problem that I can't solve...ATI dampers are pretty simple. They have different o-rings you can use for different applications. In some cases it may require some tuning for your engine. Also, it's important that the hub for the ATI damper is press fit correctly (about .0009" is ok). I doubt many people who installed the ATI damper actually checked the hub ID and crank snout OD to verify there was the proper press fit. Furthermore, if it was not quite right...how many people do you think actually had the crank pulley honed to the correct size?I'm using a proper dial bore gauge to measure the crank pulley and nice micrometer to check the snout. I'll post my results.
I'll be using a 4G64 DOHC belt.
who are ? are you the brains behind mitsubishi... lol ... damn you know your stuff... subscribed
Old Jul 7, 2010, 01:08 PM
  #107
n2oiroc's Avatar
if that thing is 1.5mm over the pistons, throw it out.
Old Jul 7, 2010, 03:16 PM
  #108
wcevo8tech's Avatar
well, i could read SI swimsuit issue thought it! IF the machine shop would have done HIS homework this wouldnt have happened.
there is a bunch of drama behind the owner and the shop that closed, im just trying to make it run under its own power and see what happens.
Old Jul 7, 2010, 05:11 PM
  #109
n2oiroc's Avatar
there is no way it will run, dont ruin the pistons and rings in it and waste the gasket money. .006" piston to wall is huge. .060" is beyond what would ever make it out the door without sucking the oil pan dry.
Old Jul 7, 2010, 05:37 PM
  #110
wcevo8tech's Avatar
the wall thinkness im sure is thin, but the bore clearance is .0035, so were good there.
Old Jul 7, 2010, 07:04 PM
  #111
evo-kro's Avatar
over my head but it looks great, wish i was a baller.
Old Jul 7, 2010, 07:55 PM
  #112
n2oiroc's Avatar
oh! it sounded like you had 87mm pistons ordered and the block was 88.5mm. you had me worried.
Old Jul 7, 2010, 09:10 PM
  #113
wcevo8tech's Avatar
Yeah, i had CP custom make these, saddly no body along the way ever cracked open a book to see what the proper bore size should have been. Believe me id rather have had to look for a 2.0 block than to do this BS again.
thanks to all that have givin imput, you Evo guys are cool!
Old May 7, 2013, 09:54 AM
  #114
anwkid's Avatar
How did you get those prices from lesco? I was just there getting prices for the exact same machining and they wanted nearly $2800 for an assembled short block. That's just machining and assembly! I've bought all the parts already!
SeanC
Aug 13, 2014 08:13 AM
SeanC
12
Oct 20, 2009 01:59 PM
SeanC
Jun 14, 2009 11:19 PM
SeanC
50
Mar 21, 2009 04:09 PM
SeanC
Jan 21, 2008 07:44 PM
Quick Reply: My 4G64 block after machine work *PICS*
