TOMEI Announces ARMS M7960 Turbine Kit
#33
Since I'm a big fan of Tomei, it makes me very interested in this turbo. For one thing, it looks really nice. Tomei makes quality products so we don't need to worry about it's reliability. But most of all, I'm really curious about the counter clockwise rotation.
I'm saving up for this turbo!
#34
#35
How can you guys already be complaining about a stock replacement turbo that gains 70 peak hp on pump gas and 23psi? Sometimes this forum gets so asinine it makes me sick. Show me a real comparison where a red gained 70hp peak on pump and 23psi or less.... oh wait, you can't. Until then, lets abate the hate, and patiently wait. More testing will come in time, and nothing can really be accomplish until more results are available.
#36
However, I have a Green on my car and my car put down 333whp on 91 on a Mustang Dyno on 21 psi. This pre-pro Tomei turbo put down approx 330 whp on a DynaPack at 23psi. I know we're not supposed to compare dyno numbers, but color me skeptical.
And where are you getting 70whp from?
#37
I like TOMEI products and I believe their turbos are made to good in every situation. For example: The FP Red only comes alive under race gas but on 91,92 or 93 Octane it will loose lot of spool. So what is the point for the FP Red if you don't run it on Race gas all the time. I like quick spool and top end. I believe that this unit will be what I am looking for. I am not here to bash on anyone I just want to see dyno numbers on a everyday stock internal engine on 91,92 or 93 octane. I will then make my decision period.
#39
You're right, it's early.
^ thats where I got 70hp from. Whp, maybe not? I have no clue, its a pretty weak graph, but as I understand it is a comparison between the evo9 turbo and the tomei at 1.6bar. If I understand this graph correctly, then I am impressed.
#41
After further research it seems this might be interesting. Comparing it to the BBK might be a good starting point, but it doesnt seem to be in any independent hands for testing yet.
I would be interested in some dynojet numbers so I have something to relate to boost to boost and timing numbers to timing numbers. Dynapaks are typically close to Mustangs (depending on operator and correction factor) so I can kind of Grok it based on that.
When is the release date?
#43
JB it is being sold through the vendor EVO 8/9 external power for sale section Edit: looks like it will be available end of Jan early Feb
I am hoping you, razorlab, or other forum tuner will get one through your shop to get some good testing
#44
The compressor inducer is 52.5mm, and the exducer is 68mm (same as stock). This compares very closely to the Green. It's a 6 blade wheel though, wondering if they're the same/similar wheel as the TC.com 20g.
The thing that gets my attention is the compressor housing. Upon first glance, it looks like they just cast a knock-off of the IX housing, but when you look at them side by side it appears larger in the same way an IX housing is larger than a VIII. This could mean better flow for a given wheel size, and also the potential for a larger wheel down the road.
It's good to see more competition in the bolt-on upgrade arena, everyone benefits.
#45
