Valve Train Opinions:: Cossy,BC,FP,ST ? Which One ?
Alright thanks a lot HeadGames for the info. Looks like Im going to go for springs, retainers, seats, locks, and guides from Ferrea. Ill be mainly daily driving the car and the driving it to the track often hopefully this year coming.
THanks again for the insight.
I have been read alot of posts bashing BC. I have the BC nitride coated valves and the BC pro series rods. Pistons are CP and my springs and retainers are WORKS. Any input on the BC stuff I have? should I worry about the valves? I figure Crower has been making rods forever, so I figured I couldn't go wrong there. Am I wrong?
Your valves are probably fine. You see 1000 places selling private label valves and most of them are made in the same plant. The same goes for his springs...someone else makes them. You read bad stuff about BC because of issues on cam centerlines being off and some other quality control issues. Some of the same guys that badmouth the BC stuff are running the parts by the company that makes BC
We use Ferrea valves for two reasons...1: We spend less time on the valve grinder with them. They are always round, always straight, and I can't say that for other valve mfgs. When we have an issue, they listen. That means something to me. 2: They make us a custom valve and it is easy to have changes made. I don't run a Ferrea spring anymore because we were going for something a little more exotic that will last longer, but for EVOs...Ferrea stuff fits snug and lasts awhile. You guys pushing big power should easily be replacing springs twice a season depending on how hard you are running your car.
Ferrea components get my vote...they are a tried and true product, and are used in engines making ginormous amounts of power and are rev'd to retarded engine speeds. However I just wanted to mention that stiffer valve springs affect a number of things. While over all they are definitely beneficial, and everything depends on HOW STIFF you go, but lets just say for now, the stiffer you go, the more you will decrease your chance of valve float at high revs, and the more you will increase your chances of different types of mechanical failure from:
-Over stressing the timing belt- (people forget that the stiffer the spring, the more tension there is on the actual timing belt). A kevlar timing belt is a VERY good idea when using stiffer springs
-Adjustable cam gear failure- Make sure you use a quality adjustable cam gear, because with stiffer springs comes more torsional stress on the cam gears. If it slips can say ADIOS to your expensive little engine.
-Camshaft deflection or camshaft bearing failure-stiffer springs put more loading on the camshafts themselves, which over time can cause excessive wear on the bearings, or even crack one of the bearing caps.
I think this about covers it. Happy revving!
What is big power?!? I don't hit the road course every weekend but I drive it to work every day...sometimes a little faster then others How often should the springs be changed if the car is daily driven, track day car?
If I was running over 500hp and a good spring like a Ferrea, I would check them for fatique at 6 months. I have murdered springs long before that, but it isn't realistic to tell people to do it more often than that. You will probably find that they are perfectly fine and can go right back in and be pissed at the a** online that suggested it I hate working on cars so do like me and just let it ride and face the consequences later
One of the reason's (other than what I previously mentioned) I went from a Ferrea to a PSI spring was that the PSI holds up more than twice as long...and at that point is it easier to maintain and more economical. With these itty bitty EVO cams, a Ferrea spring will last a LONG time.
While I have several Ferrea dual spring valve train setups, I will simply observe that Kiggly has done an enormous amount of valve spring testing during his career of engineering and modifying his 4g63 powered FWD racecar to be one of the fastest FWD race cars in the world. That's why the Kiggly bee hive springs are highly regarded and recommended. He didn't just find them in a supplier catalog somewhere and put his name on them...
snowmastergt
12
Nov 30, 2012 02:03 PM
BSREVOLUTION
57
Jun 28, 2011 09:46 AM
RUN FOREST RUN
18
Jun 16, 2008 06:33 PM
