Walbro Install Help
Walbro Install Help
I just got done installing my FP Walbro (342?) pump and the car wont start... The car cranks fine and I had another set of hands tell me that the pump does appear to be running while cranking, then when I stop cranking the pump whines higher before turning off. What is my issue? Im worried I did some damage to the wire harness while pulling the pump from the main housing, does this sound like an issue even given the pump is clearly running? Thanks!
if the install is anything like the walbro 255 install then its the doughnut hose not being lined up properly. Check my website for the install where i go over the not starting issue.
http://www.cardomain.com/ride/3123213/6
Okay, I just removed that black plug with the black wire running to it and reseated the o-ring on to the black plug and no joy. I still think that the issue lies with this o-ring, how is it supposed to fit into the small cylinder? If you look up into it there is a very small black pad with a metal tab sticking out from under it and the black plug im referring to has a smaller diameter cylinder which is the size of the inner diameter of the o-ring. Someone help me out!
EDIT: Is the ring supposed to sit all the way DOWN on the black plug or on TOP of the plug?? I put it all the way on the plug, maybe this is wrong...
You have to pull the pump back out of the assembly. If the o-ring isn't on the pump then look down the part of the assembly where the pump fit in.
Take a look at RockmanX's link and scroll to nearly the bottom where he does the Walbro install. In the white housing next to the cylinder for the pump itself there is another small cylinder with a black plug and black wire on the bottom of it. If you remove that clip, there is a small o-ring inside. This o-ring could definitely obstruct the fuel path if in the wrong position and there clearly some type of electrical connection there. This appears to be some kind of inertia cutoff switch and if the o-ring and clip are in the wrong position, the fuel will not flow. I am wondering where the o-ring should go, I would assume there are only two positions, between the small metal prong in the cylinder and the top of the black plug, or pushed all the way down on the black plug, the way I have it now with no function. I now have no clue how it goes on. Is there a diagram of the whole housing in the Service Manual that I am missing?
