power steering fluid
ATF, doesn't matter what kind..
A Mitsu technician I talked to said using OEM power steering fluid is important enough that when he found his dealership didn't carry it he insisted that they get it.
I don't know what OEM power steering fluid is but it is a different product. When I stopped at the Mitsubishi dealership in Fort Collins, Colorado, I was sold ATF as power steering fluid. When I told my Mitsubishi technician friend, he was steamed.
Last time I looked, Mitsu calls for diamond SP3, which is atf. Even if its not, your tech friend needs to chill out. Power steering is simply a hydraulic system, it doesn't have crazy fluid requirements unless its an electro-hydro rack, and our cars are't. ATF is glorified hydraulic fluid with extra detergents (a lot of them). You'll be fine. Ford, for example, has used the same fluid for transmissions and power steering since forever..
Oh the old debate. People saying ATF and PSF are the same are the same people who suggest that napa oil is the same as amsoil - or "oil is oil" and "hydro is hydro." It's not exactly the same nor is it the best thing you can use. So if your the type that forks up for Amsoil or Brad Penn in your engine, then you should also use the recommended PSF in your power steering. Those of you that have drums of ATF and don't mind or care then by all means.
Power steering is just a simple rotary vein pump, and in the case of a power rack a spool/rotary valve on the input shaft, and a hydraulic cylinder. You can put in it whatever you want. It's a hydraulic system that strains the fluid far less than a transmission.
Certain cars do require specific fluid. Honda being one of them due to specific additives they want in the fluid, and most Euro's call for mineral oil. And the electro-hydro systems call for special fluid typically. But that's it.
Also, ATF is only red because it is dyed red. Imagine the confusion if it wasn't dyed, then people really wouldn't know what to use because it would be the same color as PSF...
Also, just looked it up. Mitsu rec's PSF, Diamond SP, or Diamond SPIII. So, it would seem mitsu doesn't really care what goes in it..
I just bought some OEM PSF for my 2005 Evo VIII from Mitsubishiparts.net. It came in a 1 liter (34 ounce) metal can, with both Japanese and English writing. It was labeled DiaQueen PSF part 4039645. And it was red. Don't know if it is identical to OEM ATF or not, but as long as the sell a separate PSF, that's what I use when I want OEm
Also, what are the conditions to check the level to see if it is properly between min and max? Running or engine off? Hot or cold? I am used to my GMC truck having a Hot line and Cold line, not a min and max line.
Running, and hot.
