Turbo kit GT3037S
![Question](https://www.evolutionm.net/forums/images/icons/icon5.gif)
My name is John, I'm from Russia and I have EVO6. I tried to install turbo kit HKS Kansai GT3037S and there is a problem: inlet diameter in turbine is 100mm, but standart air flow sensor is about 70mm. What should I do in this situation?
Car equipted:Apex Power FC+commander, AVCR, HKS SQV, KOYO radiator, HKS intercooler Type R, oil cooler, Bosch fuel pump, Power injectors 700cc, pistons HKS Kansai 85mm, head gasket 1.6, HKS fuel rail, LSD front rear center KAAZ, HKS final set 4.111, sequental shifter.
Waiting for TODA stroker kit 2323cc, JUN 264 camshafts+springs+adj.pulleys.
Re: Turbo kit GT3037S
I know my russian sucks.
I would suggest to get the HKS intake pipe and Hyper filter. The compersser inlet is just to large for stock.
Now if your able to tune Via MAP from your Power FC just get rid of the MAF all together and put a filter onto the inlet.
I have attached a pic of the HKS inlet pipe and filter.
Paka
Eric
Arkady@rmscorp.com
the HKS Suction kit pipe is only large on the intake end, on the other end, where it attaches to the turbo, is the same diameter as the stock. HKS 3037S mouth diameter is around 4+ inches, while the suction kit inlet pipe is around 2.5 inches. IT WILL NOT FIT. Godzilla, I would just recommend that you make a 4 inch custom inlet pipe connected to any kind of Air filter cone or cold air induction box.
Godzilla - Wow a guy in Russia named John (kinda American) with a Japense Monster for a Handle with a Japanese Rocket for wheels! What a wierd whacky and wild world, heh!
How is the racing scene in russia? Are there many race tracks to enjoy?
You need the same intake kit as me, HKS Kansai Intake kit for 30/37 turbo kit, here is the kit installed.
http://www.kansaiss.co.jp/mct9a.htm
Hi,
Sorry for my English.
Not many, people uses old airports for drag racing 402m.
http://www.auto.vl.ru/gtclub/picture...3/P1010067.JPG
http://www.auto.vl.ru/gtclub/picture...3/P1010068.JPG
Re: Re: Turbo kit GT3037S
http://www.kansaiss.co.jp/parts/kpm004.htm
EVO(boss)
17
Jun 26, 2009 08:21 AM
BPAuto
26
Jan 27, 2004 10:44 AM
