AEM wideband giving weird readings..help
My aem wideband just starting acting weird ever since it started getting really cold and now even warm..still act the same... its reading lean all the time..the reading shows --- and stays there but sometimes would jump to 17.9 and stay there then today jump to 10.1 and stay there... im not really sure what happened..if something shorted or rubbing giving weird readings... i had the connector came off before and the reading was at 14.7 if i remembered... check the connectors and its connected solid...not really sure what happened...
Who welded it, The weld could be giving. Mine was doing the same thing and it's because it wasn't welded all that well the first time.
If the weld is good then the o2 could have fouled out if the car was running really rich. I would def check for any exhaust leaks in or round the o2 bung though!
G/L
G/L
i had one of my buddy shop weld it for me..looked pretty good to me....my car wasn't really running rich as far as i can tell when the wideband was still working but i will double check everything to make sure nothing is loose...
i took everything apart today and found there is corrosion/gfs on one of the pins on the connector...i cleaned both side up with some maf cleaner and tested it....its now stuck at 10:1 and slowly climbing to 18:1 then --- and stays there... so i took the wideband sensor out...the sensor is covered in carbon build up...im guessing its fouled... does aem sell just the sensor? anyone know pricing of it?? and where to get it?
Yeah, you can buy just the sensor. its part #30-2001 when you're looking for it.
http://www.aempower.com/ViewProduct.aspx?ProductID=624 $86
http://shopping.lightningmotorsports...productid=1744 $69
superkizuna
30
Mar 19, 2014 08:09 PM
147, acting, aem, band, connector, evo, good, pins, reading, readings, troubleshoot, troubleshooting, understand, wide, wideband
