Oil pan heater?
Oil pan heater?
Ok i live in alaska and i am having a difficult time to get my car to start every day and i need to find a oil pan heater or engine block heater. does any one know the size of the oil pan or any kits that fit their evo or even better a kit that is designed for the evo?
i use a nitrous express bottle heater on my dry sump resevior. i've seen other cars use some expandable wire coils that heat up on other dry sump systems. you could probably rig something like that up.
Oil pan heaters are pretty generic, its basically just a had pad glued to the bottom of the oil pan. As for as block heaters go i'm sure the dealer could get you the proper one.
Berndog67
Aug 3, 2017 04:25 PM
