Car will not idle/stay running
Car will not idle/stay running (updated, I'm even more confused)
UPDATE (1/12): I went through last night and put a DV on, and checked at the stock soft pieces of IC piping for holes. It started up and idled for 30 minutes after, and then I went to drive it, and as soon as I got in the street, it died(at running temp).
Well, I started it up this morning and it ran fine, so I turned it off and left. I came home tonight, put it in reverse to back it out of the garage, and then parked it out side.
It stayed running with no problems. Once it got up to operating temp, I pulled out of the driveway to drive it, and it died once again. I am lost.
Well, last night I was driving to downtown, and as soon as I got off of the highway and stopped at the light, my car just shut off.
Since then, the car runs perfectly fine once I begin moving, but it will not idle at all, it just shuts right off.
To start it, I have to turn it over, and then begin to give it gas. When driving, any time I come to a stop sign or light, it will shut off unless I push the clutch in and give it a little gas.
Has anyone had this problem, or does anyone have any idea what it could be?
I have looked at all of the couplers and vacum lines, and it all appears to be in good shape.
Thanks for any help
Anthony
FWIW, my mods that could affect this are Walbro 255, an intake, and Forge DV.
Othe than that, I cannot see any of my mods being related to this issue.
Thanks for any help
Anthony
Thanks for the help so far guys.
I put the stock DV on it today, and it idled at first, but the next time I went to start it, it continued to not run. I ordered new UICP and a new DV, so if that doesn't fix it, I will try the IACV. Any ideas where to get those cheap?
Also, if you have any other ideas of what could be causing this, please continue to post.
Anthony
Anthony
I wouold pull out your ecu and take off the cover and look if anything like the capacitors burst open or are leaking (my ecu was casuing the fuel pump to turn off). I had the same problem on my dsm (theory should be similar) and the caps were leaking bad. If that is the case, I'd suggest contacting this guy:
http://www.dsmtuners.com/forums/members/steve-164.html
He is a electronics ecu guru and has repaired a many ecu's including mine (dsm that is, my 9's too new to have its fried)
or this guy
http://cgi.ebay.com/ebaymotors/Mitsu...Q5fAccessories
or this guy
I had a similar problem except my car wouldn't idle at all....and I just replaced (today) my IAC with a used one from Aby@Mil.Spec and it idles like nothing was ever wrong with it!!
I would suggest checking your IAC as that may be your culprit.
Man...I've been chasing an idle problem too. I have many more mods that could be in question..anyone think an IACV can go bad in 21k miles? Is there any other way to "test" it than swapping it out?
There is a way of testing the IAC...I was told to unscrew the 3 screws holding in the IAC and leave the electrical connector on....have a friend turn over the the motor while you see if the IAC actuates/moves when cranking....something to that effect...not 100% sure if this is the CORRECT way but it was suggested to me.. I did not test this method in order to back up this testing method.
randomevo
Dec 18, 2016 11:11 AM
turbocheese
16
Nov 19, 2015 09:16 AM
EvilTechnology
Jun 24, 2015 09:22 PM
